Zum Hauptinhalt wechseln
Hoover WindTunnel 2 Rewind Belt and Roller Brush Replacement
Was du brauchst
  1. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: Schritt 1, Bild 1 von 2 Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: Schritt 1, Bild 2 von 2
    • Remove the four 20 mm Phillips #1 head screws holding the top cover on.
    • Lift off the cover.
  2. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: Schritt 2, Bild 1 von 1
    • Grab on both ends of the roller brush, lifting it and the attached belt clear of the housing.
  3. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: Schritt 3, Bild 1 von 2 Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: Schritt 3, Bild 2 von 2
    • Reinstall belt and roller making sure that the white text is facing outwards on the belt.
    • Placing the roller brush in its guides will put some tension on the belt after the roller is in place spin it with your hand a couple times to ensure that it spins freely.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S11-G4, Banghart Winter 2018 Mitglied von Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
5 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Thank you, made it easy peasy!
J Colee - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 23
Letzte 30 Tage: 110
Insgesamt: 8,555
