Einleitung
Replace your dirty or broken dust cup filter with these easy steps!
Was du brauchst
Press button on the top of the dust cup and pull back.
Remove dust cup from vacuum
Lift up on fabric flap to remove filter from vaccum
If you wish to clean the filter rather than replace it, it can be washed under a faucet.
Holding onto both the top handle and dust cup body, twist the two components apart following the instructions printed on the back.
Unscrew the three 4 cm Phillips #3 screws located inside the dust filter compartment to detach the dust filter system.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
