Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The primary air filter is in the vacuum's dust cap and prevents dust from being sucked out of the dust cup.
It's designed to be easily cleaned or replaced, so it's a quick process.
If your filter merely needs to be cleaned, you can follow this guide, but instead of replacing the filter you can rinse it under a faucet and reinstall it.
Werkzeuge
Keine Werkzeuge angegeben.
Ersatzteile
  1. Press button on the top of the dust cup and pull back.
    • Press button on the top of the dust cup and pull back.
    • Remove dust cup from vacuum
  2. Pull back on black lever and rotate dust cup lid back.
    • Pull back on black lever and rotate dust cup lid back.
  3. Lift up on fabric flap to remove filter from vaccum
    • Lift up on fabric flap to remove filter from vaccum
    • If you wish to clean the filter rather than replace it, it can be washed under a faucet.
    • If washing the filter, make sure it fully dries out before re-installing.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Joshua Anderson
254 Reputation
1 Anleitung geschrieben
Cal Poly, Team S11-G4, Banghart Winter 2018 Mitglied von Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
5 Mitglieder
5 Anleitungen geschrieben
Can I rinse it with warm water and soap? Or just warm water?
lacey sodapop - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 44
Insgesamt: 1,148
