Einleitung
This guide will help assist you with removing and replacing the motor assembly in your Hoover UH72400.
Was du brauchst
Put the cleaner into the upright position, turn the power off, and unplug the power cord.
Remove the dirt cup from the cleaner.
Twist the top counterclockwise to unlock the cap.
Use a plastic spudger or opening tool to press on the small circle and wiggle clips free.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
