Zum Hauptinhalt wechseln
Hoover Windtunnel Air Steerable Upright Motor Assembly Replacement
Was du brauchst
  1. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: Schritt 1, Bild 1 von 2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: Schritt 1, Bild 2 von 2
    • Put the cleaner into the upright position, turn the power off, and unplug the power cord.
  2. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: Schritt 2, Bild 1 von 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: Schritt 2, Bild 2 von 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: Schritt 2, Bild 3 von 3
    • Remove the dirt cup from the cleaner.
    • The HEPA filter is located under the dirt cup and under where it says HEPA.
    • Twist the top counterclockwise to unlock the cap.
  3. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: Schritt 3, Bild 1 von 2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: Schritt 3, Bild 2 von 2
    • Lift the HEPA filter out.
    • Tap the filter against the inside of a trashcan to knock out the dirt and debris or replace as necessary.
    • Do not wash the HEPA Filter.
  4. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: Schritt 4, Bild 1 von 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: Schritt 4, Bild 2 von 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: Schritt 4, Bild 3 von 3
    • Remove the 4 retaining screws and remove the filter tray.
    • Screw lengths are approximately 3/4".
  5. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: Schritt 5, Bild 1 von 1
    • Pull the motor housing vertically to dislodge the motor.
  6. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: Schritt 6, Bild 1 von 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: Schritt 6, Bild 2 von 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: Schritt 6, Bild 3 von 3
    • Use a plastic spudger or opening tool to press on the small circle and wiggle clips free.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
steven hoover
257 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S7-G2, Banghart Fall 2017 Mitglied von Cal Poly, Team S7-G2, Banghart Fall 2017
CPSU-BANGHART-F17S7G2
5 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 54
Insgesamt: 3,870
