Einleitung
Use this guide to replace the electrical cord on the Hot Tools HPK12 Titanium Flat Iron.
The cord provides power to the flat iron. You will know if the device is working if the metal plates are hot when the cord is plugged in. Do not plug in a frayed or cracked cord.
Changing the electrical cord is a four-step process. Each step includes easy to follow instructions and a photo that demonstrates what you need to do.
Note that step three will require strength.
Was du brauchst
Slide the black O-ring out of its channel and pull it off the end of the flat iron.
Separate the top and bottom pieces of the shell. It may require some force to break the seal.
Remove the cord by pulling up and away from the bracket. You are now ready to replace the cord.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Where can I get a replacement cord? You only show how to removed it but not how to fix it
