Zum Hauptinhalt wechseln
Hot Tools HPK12 Heating Plate Replacement
Was du brauchst
  1. Hot Tools HPK12 Heating Plate Replacement, Prerequisite Only: Schritt 1, Bild 1 von 3 Hot Tools HPK12 Heating Plate Replacement, Prerequisite Only: Schritt 1, Bild 2 von 3 Hot Tools HPK12 Heating Plate Replacement, Prerequisite Only: Schritt 1, Bild 3 von 3
    • Remove round plastic cover near cord base by prying under the side with the metal spudger.
    • Flip the device and remove the other round plastic cover near the base of the cord.
    • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
  2. Hot Tools HPK12 Heating Plate Replacement: Schritt 2, Bild 1 von 1
    • Use the metal spudger to push the center pin through to the other side.
  3. Hot Tools HPK12 Heating Plate Replacement: Schritt 3, Bild 1 von 2 Hot Tools HPK12 Heating Plate Replacement: Schritt 3, Bild 2 von 2
    • Lift back plastic cover to expose spring assembly.
    • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
    • Grip the exposed end of the spring assembly and remove it.
    • The side with the two ends of the spring goes into the recessed area of the iron
  4. Hot Tools HPK12 Heating Plate Replacement: Schritt 4, Bild 1 von 1
    • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
  5. Hot Tools HPK12 Heating Plate Replacement: Schritt 5, Bild 1 von 3 Hot Tools HPK12 Heating Plate Replacement: Schritt 5, Bild 2 von 3 Hot Tools HPK12 Heating Plate Replacement: Schritt 5, Bild 3 von 3
    • Lift upward on the control assembly cover to remove it from the flat iron base.
    • Remove dial and switch cover and set aside.
  6. Hot Tools HPK12 Heating Plate Replacement: Schritt 6, Bild 1 von 3 Hot Tools HPK12 Heating Plate Replacement: Schritt 6, Bild 2 von 3 Hot Tools HPK12 Heating Plate Replacement: Schritt 6, Bild 3 von 3
    • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
    • Lift the backing plate upwards to remove it from the flat iron.
    • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
  7. Hot Tools HPK12 Heating Plate Replacement, Heating Plates: Schritt 7, Bild 1 von 1
    • Lift plate and circuit assembly away from flat iron case.
  8. Hot Tools HPK12 Heating Plate Replacement: Schritt 8, Bild 1 von 1
    • Flip device to access the non-control assembly flat iron arm and remove two 3.5mm “J0” screws that attaches cover to flat iron base.
  9. Hot Tools HPK12 Heating Plate Replacement: Schritt 9, Bild 1 von 1
    • Lift cover from flat iron case.
  10. Hot Tools HPK12 Heating Plate Replacement: Schritt 10, Bild 1 von 2 Hot Tools HPK12 Heating Plate Replacement: Schritt 10, Bild 2 von 2
    • Lift heating plate away from flat iron case.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
IUPUI, Team 3-4, Baechle Fall 2016 Mitglied von IUPUI, Team 3-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 847
