Zum Hauptinhalt wechseln
Hot Tools Professional 1110 Heating Coil Replacement
Was du brauchst
  1. Hot Tools Professional 1110 Heating Coil Replacement, Hot Tools Professional 1110 Disassembly: Schritt 1, Bild 1 von 1
    • Ensure that you have a clean work station, and that you can easily keep track of small, loose parts.
    • In addition, MAKE SURE IT IS UNPLUGGED FOR ALL FOLLOWING STEPS!
  2. Hot Tools Professional 1110 Heating Coil Replacement: Schritt 2, Bild 1 von 2 Hot Tools Professional 1110 Heating Coil Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Firmly grasp the end of the Iron with the black plastic cap on the heating element end.
    • With your free hand, use tweezers to firmly grasp the small retaining ring sitting between the heating element and the handle body.
    • Once you have a firm grasp, pull up on the retaining ring, and it should come loose.
  3. Hot Tools Professional 1110 Heating Coil Replacement: Schritt 3, Bild 1 von 1
    • With the ring loose, turn the handle body over, and you will see three screw holes.
    • Take a PH1 screwdriver, and loosen up all three 6mm Phillips #1 screws in the handle body.
  4. Hot Tools Professional 1110 Heating Coil Replacement: Schritt 4, Bild 1 von 1
    • Once the screws have been removed, set them aside and with a pry tool, firmly pull the handle body apart in half lengthwise.
  5. Hot Tools Professional 1110 Heating Coil Replacement: Schritt 5, Bild 1 von 2 Hot Tools Professional 1110 Heating Coil Replacement: Schritt 5, Bild 2 von 2
    • For removing the clamping mechanism, firmly grasp the iron in your hand by the handle body, and locate the screw as shown in the picture.
    • Remove the screw shown (8mm Phillips #2 Pan Head) and when finished do the same for the opposite side.
  6. Hot Tools Professional 1110 Heating Coil Replacement: Schritt 6, Bild 1 von 1
    • Once both screws have been removed, continue to remove the top clamping half of the mechanism from the body of the Iron.
  7. Hot Tools Professional 1110 Heating Coil Replacement: Schritt 7, Bild 1 von 1
    • Rotate the handle, and remove the screw that holds on the spring mechanism for the clamp. This screw is a 8mm Phillips #2 Pan Head.
    • Once this step is fished your Hot Tools Professional 1110 will be fully disassembled and ready to have its components replaced.
  8. Hot Tools Professional 1110 Heating Coil Replacement, Heating Coil: Schritt 8, Bild 1 von 1
    • Remove the board gently from its location. Note how its shape fits its location for easy assembling.
  9. Hot Tools Professional 1110 Heating Coil Replacement: Schritt 9, Bild 1 von 1
    • The white cable is the heating coil. It is powered through the board by the power switch. It has three small wires that are soldered on the board.
    • Desolder the three wires as shown on the picture. Mark the location of each wire.
    • Refer to Hot Tools Professional 1110 Power Switch Replacement for more guidelines.
  10. Hot Tools Professional 1110 Heating Coil Replacement: Schritt 10, Bild 1 von 1
    • Replace a new heating coiling by soldering as shown in the picture.
Abschluss
Muana Kasongo
101 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G2, Wilson Fall 2017 Mitglied von IUPUI, Team S2-G2, Wilson Fall 2017
IUPUI-WILSON-F17S2G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 303
