Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The Hot Wheels Race System Controller may become unresponsive due to broken or disconnected wires. Heavy use or dropping can cause these disconnections. These wires may need to be reconnected or replaced. Take care when opening the controller as more wires could break.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the six screws located on the back of the controller using a JIS #1 screwdriver.
    • Remove the six screws located on the back of the controller using a JIS #1 screwdriver.
  2. Pop the front of the controller casing from the back and carefully lay the controller out with circuits exposed.
    • Pop the front of the controller casing from the back and carefully lay the controller out with circuits exposed.
  3. Check all wires for disconnections. They are color coated red, black, orange, and yellow. If wires are disconnected they can easily be reinserted as shown in photos.
    • Check all wires for disconnections. They are color coated red, black, orange, and yellow. If wires are disconnected they can easily be reinserted as shown in photos.
    • Some wires may require soldering which can be done with a soldering iron. The wire marked in red may need to be soldered but can sometimes be reattached.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Luke Marshall
625 Reputation
4 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 2
Insgesamt: 180
