Zum Hauptinhalt wechseln
Hott T725-8G Screen/Display Replacement
Was du brauchst
  1. Hott T725-8G Screen/Display Replacement, Screen/Display: Schritt 1, Bild 1 von 1
    • Use the Metal Spudger tool and your fingers to peel off any existing screen protector.
  2. Hott T725-8G Screen/Display Replacement: Schritt 2, Bild 1 von 1
    • Remove black electrical tape to release the sensor and ribbon wires connecting the camera to the motherboard.
  3. Hott T725-8G Screen/Display Replacement: Schritt 3, Bild 1 von 1
    • Dislodge the sensor from the front panel.
  4. Hott T725-8G Screen/Display Replacement: Schritt 4, Bild 1 von 2 Hott T725-8G Screen/Display Replacement: Schritt 4, Bild 2 von 2
    • Use a pair of Precision Tweezers to squeeze the clip of the ribbon wire to release it.
  5. Hott T725-8G Screen/Display Replacement: Schritt 5, Bild 1 von 3 Hott T725-8G Screen/Display Replacement: Schritt 5, Bild 2 von 3 Hott T725-8G Screen/Display Replacement: Schritt 5, Bild 3 von 3
    • Using a pair of the Precision Tweezers, remove the ribbon wire from the clip.
  6. Hott T725-8G Screen/Display Replacement: Schritt 6, Bild 1 von 1
    • Follow the guide to remove the motherboard from the back of the display.
  7. Hott T725-8G Screen/Display Replacement: Schritt 7, Bild 1 von 1
    • Follow the guide to remove the battery from the back of the display.
  8. Hott T725-8G Screen/Display Replacement: Schritt 8, Bild 1 von 1
    • With the motherboard and battery detached, use the Metal Spudger tool to gently remove the display from the front panel.
  9. Hott T725-8G Screen/Display Replacement: Schritt 9, Bild 1 von 1
    • Remove Digitizer Panel from the front panel.
  10. Hott T725-8G Screen/Display Replacement: Schritt 10, Bild 1 von 1
    • Remove the LCD 5-Point Touch Screen from the display case.
  11. Hott T725-8G Screen/Display Replacement: Schritt 11, Bild 1 von 1
    • Remove the display from the plastic casing. The screen is now ready for replacement.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Emma Carroll
193 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 6-2, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 6-2, Martin Fall 2016
UMASSD-MARTIN-F16S6G2
3 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 309
