Einleitung
This guide will show you how to replace the LED headlights on the front of the Hover-1 Chrome. You will need a Phillips #2 screwdriver.
Was du brauchst
Flip the Hover-1 Chrome upside down.
Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
Lift the shell with the speaker grille.
Unplug the speaker.
Unplug the LEDs.
Unplug the power button
Unplug the charging port.
Use a Phillips #2 screwdriver to remove the two 2 mm screws on either side of the LEDs.
Remove the LED board.
Locate the LED headlights on the left side of the board.
Pull the red wire attached to the LEDs perpendicular to the other wires to disconnect it.
