Zum Hauptinhalt wechseln
Hover-1 Chrome LED Headlights Replacement
Was du brauchst
  1. Hover-1 Chrome LED Headlights Replacement, Hover-1 Chrome Disassembly: Schritt 1, Bild 1 von 1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome LED Headlights Replacement: Schritt 2, Bild 1 von 1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome LED Headlights Replacement: Schritt 3, Bild 1 von 2 Hover-1 Chrome LED Headlights Replacement: Schritt 3, Bild 2 von 2
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome LED Headlights Replacement, LED Headlights: Schritt 4, Bild 1 von 3 Hover-1 Chrome LED Headlights Replacement, LED Headlights: Schritt 4, Bild 2 von 3 Hover-1 Chrome LED Headlights Replacement, LED Headlights: Schritt 4, Bild 3 von 3
    • Use a Phillips #2 screwdriver to remove the two 2 mm screws on either side of the LEDs.
    • Remove the LED board.
    • The LEDs are not symmetrical. This step is for the right side of the board, next to the power button. The left side is covered next.
  5. Hover-1 Chrome LED Headlights Replacement: Schritt 5, Bild 1 von 2 Hover-1 Chrome LED Headlights Replacement: Schritt 5, Bild 2 von 2
    • Locate the LED headlights on the left side of the board.
    • Pull the red wire attached to the LEDs perpendicular to the other wires to disconnect it.
  6. Hover-1 Chrome LED Headlights Replacement: Schritt 6, Bild 1 von 3 Hover-1 Chrome LED Headlights Replacement: Schritt 6, Bild 2 von 3 Hover-1 Chrome LED Headlights Replacement: Schritt 6, Bild 3 von 3
Abschluss
Nick McGuire
551 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S4-G1, White Fall 2018 Mitglied von Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 172
