Einleitung
You will need a Phillips #2 screwdriver and a soldering iron.
Was du brauchst
Flip the Hover-1 Chrome upside down.
Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
Lift the shell with the speaker grille.
Unplug the speaker.
Unplug the LEDs.
Unplug the power button
Unplug the charging port.
Disconnect the speaker cable.
Disconnect the cable that travels to the other sensor board.
Disconnect the smaller connector midway on the cable.
Disconnect the larger connector midway on the cable.
Locate the five solder locations on the underside of the gyroscope sensor board.
Plug in soldering iron and wait for the tip tip to reach its target temperature.
Rest the tip of the iron on the solder and wait for the solder to melt. The wire will drop out of the sensor board.
