Einleitung
In order for your Hover-1 Coast to be used for its intended purpose you must have a functioning battery. This procedure is fairly easy to accomplish and key to using the board to its full potential.
Was du brauchst
To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
Using a pick tool, puncture the grip tape and expose the screws.
Loosen all four 1" screws using a Phillips #1 screwdriver.
The battery is connected by these two sets of wires.
Remove the yellow wire first by pulling the two wires gently in opposite directions.
Now pull apart the black wire by gently pulling the two wires in opposite directions.
Once the battery has been disconnected, gently pry the battery upward.
Once the battery is freed, remove it with your hands.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
