Zum Hauptinhalt wechseln
Hover-1 Coast Power Button Spring Replacement
Was du brauchst
  1. Hover-1 Coast Power Button Spring Replacement, Board Battery: Schritt 1, Bild 1 von 3 Hover-1 Coast Power Button Spring Replacement, Board Battery: Schritt 1, Bild 2 von 3 Hover-1 Coast Power Button Spring Replacement, Board Battery: Schritt 1, Bild 3 von 3
    • To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using a pick tool, puncture the grip tape and expose the screws.
    • Loosen all four 1" screws using a Phillips #1 screwdriver.
  2. Hover-1 Coast Power Button Spring Replacement: Schritt 2, Bild 1 von 3 Hover-1 Coast Power Button Spring Replacement: Schritt 2, Bild 2 von 3 Hover-1 Coast Power Button Spring Replacement: Schritt 2, Bild 3 von 3
    • Now pull the black protective cover off the board.
    • Locate the battery.
  3. Hover-1 Coast Power Button Spring Replacement: Schritt 3, Bild 1 von 3 Hover-1 Coast Power Button Spring Replacement: Schritt 3, Bild 2 von 3 Hover-1 Coast Power Button Spring Replacement: Schritt 3, Bild 3 von 3
    • The battery is connected by these two sets of wires.
    • Remove the yellow wire first by pulling the two wires gently in opposite directions.
    • Now pull apart the black wire by gently pulling the two wires in opposite directions.
  4. Hover-1 Coast Power Button Spring Replacement: Schritt 4, Bild 1 von 3 Hover-1 Coast Power Button Spring Replacement: Schritt 4, Bild 2 von 3 Hover-1 Coast Power Button Spring Replacement: Schritt 4, Bild 3 von 3
    • Once the battery has been disconnected, gently pry the battery upward.
    • It is important to use a plastic opening tool to avoid puncturing the battery.
    • Once the battery is freed, remove it with your hands.
    • The battery is glued to the case and will require some effort to remove.
  5. Hover-1 Coast Power Button Spring Replacement, Power Button Spring: Schritt 5, Bild 1 von 3 Hover-1 Coast Power Button Spring Replacement, Power Button Spring: Schritt 5, Bild 2 von 3 Hover-1 Coast Power Button Spring Replacement, Power Button Spring: Schritt 5, Bild 3 von 3
    • Using the Phillips #1 screwdriver, loosen the two screws and place the power button somewhere safe.
  6. Hover-1 Coast Power Button Spring Replacement: Schritt 6, Bild 1 von 2 Hover-1 Coast Power Button Spring Replacement: Schritt 6, Bild 2 von 2
    • Remove the unwanted spring and place your new spring back into the hole.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 356
