Einleitung
If your Hover-1 Coast board’s power button won't press you likely have an issue with the button spring. This spring allows the button to be compressed, sending a signal to the battery to turn on and power the board.
This will be a moderately difficult task to complete as you will use tools that not everyone probably has but are common for most electronics repairs.
Provided to you, is a list of detailed instructions on how to properly, and safely replace the spring. For parts please go ++here++ to look at how to purchase new parts. For any inquiries, please take a look at the operator’s manual link ++here++.
Was du brauchst
To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
Using a pick tool, puncture the grip tape and expose the screws.
Loosen all four 1" screws using a Phillips #1 screwdriver.
The battery is connected by these two sets of wires.
Remove the yellow wire first by pulling the two wires gently in opposite directions.
Now pull apart the black wire by gently pulling the two wires in opposite directions.
Once the battery has been disconnected, gently pry the battery upward.
Once the battery is freed, remove it with your hands.
Using the Phillips #1 screwdriver, loosen the two screws and place the power button somewhere safe.
