Zum Hauptinhalt wechseln
Hover-1 Coast Trucks Replacement
Was du brauchst
  1. Hover-1 Coast Trucks Replacement, Trucks: Schritt 1, Bild 1 von 3 Hover-1 Coast Trucks Replacement, Trucks: Schritt 1, Bild 2 von 3 Hover-1 Coast Trucks Replacement, Trucks: Schritt 1, Bild 3 von 3
    • In order to remove the trucks on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using the pick tool to puncture the grip tape and reveal the screws.
    • The board should look like this.
  2. Hover-1 Coast Trucks Replacement: Schritt 2, Bild 1 von 3 Hover-1 Coast Trucks Replacement: Schritt 2, Bild 2 von 3 Hover-1 Coast Trucks Replacement: Schritt 2, Bild 3 von 3
    • Once all four screws have been revealed, locate the socket wrench and the Phillips #1 screwdriver in the wrench handle.
    • Place the 9/16 inch socket wrench over the nut; place the the Phillips #1 screwdriver in the screw.
    • Hold the socket wrench in place and twist the screwdriver counterclockwise to loosen the nuts.
  3. Hover-1 Coast Trucks Replacement: Schritt 3, Bild 1 von 3 Hover-1 Coast Trucks Replacement: Schritt 3, Bild 2 von 3 Hover-1 Coast Trucks Replacement: Schritt 3, Bild 3 von 3
    • Remove the nuts from the bottom of the board.
    • Slide the unwanted trucks off the screws.
    • The black rubber spacer will stay on the board.
Abschluss
Alaina Limon
97 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 248
