Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide is created to replace a damaged or broken back wheel. Tools required are a Hex Bit 4.0 tool, a bit extender, and an allen key.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise. The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
    • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
  2. Slide off the plastic side panel. Slide off the plastic side panel. Slide off the plastic side panel.
    • Slide off the plastic side panel.
  3. Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • You will need to hold the other screw you are not replacing with an additional hex bit 4.0, so that the screws don't spin freely.
  4. Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
    • Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
  5. Slide off the other plastic side panel. Slide off the other plastic side panel. Slide off the other plastic side panel.
    • Slide off the other plastic side panel.
  6. On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • The axle pops out and the wheel easily comes off.
    • Two washers will pop out with the axle.
Abschluss
Luke Imai
133 Reputation
1 Anleitung geschrieben
Cal Poly, Team S15-G5, White Fall 2018 Mitglied von Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 Mitglieder
5 Anleitungen geschrieben
Where can you get replacement rubber for the front and rear wheels?
jackricotta - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 12
Letzten 7 Tage: 47
Letzten 30 Tage: 226
Insgesamt: 491
