Zum Hauptinhalt wechseln
Hover-1 H1 Battery Replacement
Was du brauchst
  1. Hover-1 H1 Battery Replacement, Bottom Shell: Schritt 1, Bild 1 von 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Battery Replacement: Schritt 2, Bild 1 von 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Battery Replacement: Schritt 3, Bild 1 von 2 Hover-1 H1 Battery Replacement: Schritt 3, Bild 2 von 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Battery Replacement: Schritt 4, Bild 1 von 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Battery Replacement, Battery: Schritt 5, Bild 1 von 1
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  6. Hover-1 H1 Battery Replacement: Schritt 6, Bild 1 von 1
    • Gently lift the battery harness and remove the battery by lifting the battery and moving it away from the hoverboard.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Aaron Teh
442 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S17-G6, White Fall 2018 Mitglied von Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Mitglieder
7 Anleitungen geschrieben
11 Kommentare
The stickers were the trick. I didn’t see them!
Daniel D - Antwort
After removing the 4 screws that is holding the battery in place I still can't remove the battery. I tried gently to pry under the battery but it doesn't budge. Uni Sun model HY-A01B. How do I solve this problem?
Terry Pollard - Antwort
Where do I get another battery to replace it???
Tony Pate - Antwort
That's the question I can't seem to find the answer to
Darin -
Very low quality. Bought for my son who haven’t even used it for 15 times. Got it during winter and before summer the product stopped working.
tosin3in1 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 28
Letzte 30 Tage: 169
Insgesamt: 8,997
