Einleitung
Replacing the charging port of your Hover-1 H1 hoverboard will help to solve charging problems.
Was du brauchst
Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Puncture the two black stickers by using the tip of a screwdriver.
Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
