Einleitung
This guide explains how to replace the LED headlights on your Hover-1 H1 hoverboard.
Was du brauchst
Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Puncture the two black stickers by using the tip of a screwdriver.
Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
Remove the horizontal light by using your fingers to pull the light up out of the shell.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
