Zum Hauptinhalt wechseln
Hover-1 Liberty Battery Replacement
Was du brauchst
  1. Hover-1 Liberty Battery Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Hover-1 Liberty Battery Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Battery Replacement: Schritt 2, Bild 1 von 2 Hover-1 Liberty Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Battery Replacement: Schritt 3, Bild 1 von 3 Hover-1 Liberty Battery Replacement: Schritt 3, Bild 2 von 3 Hover-1 Liberty Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
  4. Hover-1 Liberty Battery Replacement, Battery: Schritt 4, Bild 1 von 2 Hover-1 Liberty Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Disconnect the large red and black wire from the battery by pulling apart the connector.
  5. Hover-1 Liberty Battery Replacement: Schritt 5, Bild 1 von 2 Hover-1 Liberty Battery Replacement: Schritt 5, Bild 2 von 2
    • Remove the four 15mm Phillips #1 screws from the bracket holding the battery in place.
  6. Hover-1 Liberty Battery Replacement: Schritt 6, Bild 1 von 2 Hover-1 Liberty Battery Replacement: Schritt 6, Bild 2 von 2
    • Remove the bracket by pulling it upwards, away from the hoverboard.
    • You will need to move some wires aside to remove the bracket successfully.
  7. Hover-1 Liberty Battery Replacement: Schritt 7, Bild 1 von 3 Hover-1 Liberty Battery Replacement: Schritt 7, Bild 2 von 3 Hover-1 Liberty Battery Replacement: Schritt 7, Bild 3 von 3
    • Remove the battery by grasping the battery and hoverboard firmly and pulling apart.
    • The battery is held in place by adhesive. So, some force is required to remove it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Patrick Bacon
411 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S13-G2, White Fall 2018 Mitglied von Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 33
Insgesamt: 2,449
