Einleitung
If your Hover-1 Liberty is not holding a charge and there is no problem with the charging cord, then the battery needs to be replaced. In this guide, the side of the hoverboard with the words Hover-1 printed on it will be referred to as the right side.
Was du brauchst
Flip the hoverboard over so the labels are facing upwards.
Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
Remove one connector from the non-battery side circuit board.
Remove the next connector from the non-battery side circuit board.
Disconnect the large red and black wire from the battery by pulling apart the connector.
Remove the four 15mm Phillips #1 screws from the bracket holding the battery in place.
Remove the battery by grasping the battery and hoverboard firmly and pulling apart.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
