Zum Hauptinhalt wechseln
Hover-1 Liberty Bottom Cover Replacement
Was du brauchst
  1. Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Bottom Cover Replacement: Schritt 2, Bild 1 von 2 Hover-1 Liberty Bottom Cover Replacement: Schritt 2, Bild 2 von 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Bottom Cover Replacement: Schritt 3, Bild 1 von 3 Hover-1 Liberty Bottom Cover Replacement: Schritt 3, Bild 2 von 3 Hover-1 Liberty Bottom Cover Replacement: Schritt 3, Bild 3 von 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Patrick Bacon
411 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S13-G2, White Fall 2018 Mitglied von Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
I'm gettin nothin at all.. Charger is green.. But absolutely nothing when press the on button.. All the cables are connected.. No lights or anythin.. Can anyone help.
stemirnoff@hotmail.co.uk - Antwort
I am getting the 5 red lights. I have followed all the instructions. Is there a site to buy the motherboards that are burned out? Is it financially worth buy both boards and replacing them?
-Christopher Fields, Network Engineer, PC Repair, Grantsville, UT
Christopher Fields - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 3,052
