Einleitung
If your hoverboard is experiencing issues where it will not move forward or unable to maintain balance, there is a problem with the gyroscope controlling the wheels.
Was du brauchst
Flip the hoverboard over so the labels are facing upwards.
Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
Remove one connector from the non-battery side circuit board.
Remove the next connector from the non-battery side circuit board.
Remove battery connector by pulling it apart.
Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
Disconnect the colored wires by pulling them apart.
Remove the white cable from the sensor boards by disconnecting the cable on each side of the hoverboard.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
9 Kommentare
Where can you purchase the replacement board for the Hover-1 liberty?
Make this site useful by telling us where we can buy a new circuit board.
Where do you get circuit board from.
