Zum Hauptinhalt wechseln
Hover-1 Liberty Wheel Motor Replacement
Was du brauchst
  1. Hover-1 Liberty Wheel Motor Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Hover-1 Liberty Wheel Motor Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Wheel Motor Replacement: Schritt 2, Bild 1 von 2 Hover-1 Liberty Wheel Motor Replacement: Schritt 2, Bild 2 von 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Wheel Motor Replacement: Schritt 3, Bild 1 von 3 Hover-1 Liberty Wheel Motor Replacement: Schritt 3, Bild 2 von 3 Hover-1 Liberty Wheel Motor Replacement: Schritt 3, Bild 3 von 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
  4. Hover-1 Liberty Wheel Motor Replacement, Gyroscope Sensor Boards: Schritt 4, Bild 1 von 1
    • Place the hoverboard so the sensor boards face you.
  5. Hover-1 Liberty Wheel Motor Replacement: Schritt 5, Bild 1 von 2 Hover-1 Liberty Wheel Motor Replacement: Schritt 5, Bild 2 von 2
    • Remove battery connector by pulling it apart.
    • Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
    • Disconnect the colored wires by pulling them apart.
    • The large colored wires connecting the sensor boards to the wheels need to match for the motor to operate correctly.
  6. Hover-1 Liberty Wheel Motor Replacement: Schritt 6, Bild 1 von 2 Hover-1 Liberty Wheel Motor Replacement: Schritt 6, Bild 2 von 2
    • Remove the white cable from the sensor boards by disconnecting the cable on each side of the hoverboard.
    • To release the cable connector, squeeze the sides while pulling it away from the sensor board.
  7. Hover-1 Liberty Wheel Motor Replacement: Schritt 7, Bild 1 von 2 Hover-1 Liberty Wheel Motor Replacement: Schritt 7, Bild 2 von 2
    • Remove the four 10mm screws with a Phillips #1 screwdriver.
  8. Hover-1 Liberty Wheel Motor Replacement: Schritt 8, Bild 1 von 2 Hover-1 Liberty Wheel Motor Replacement: Schritt 8, Bild 2 von 2
    • Remove the sensor board by lifting it away from the hoverboard.
    • Repeat steps 4-8 to remove the sensor board from the other side.
  9. Hover-1 Liberty Wheel Motor Replacement, Wheel Motor: Schritt 9, Bild 1 von 2 Hover-1 Liberty Wheel Motor Replacement, Wheel Motor: Schritt 9, Bild 2 von 2
    • Place the hoverboard so the four 36mm Allen bolts are pointing up.
    • Remove the four 36mm Allen bolts on each side using a 5mm Allen Wrench.
    • The four Allen bolts have lock washers.
  10. Hover-1 Liberty Wheel Motor Replacement: Schritt 10, Bild 1 von 2 Hover-1 Liberty Wheel Motor Replacement: Schritt 10, Bild 2 von 2
    • Lift the metal retaining plate away from the motor shaft.
  11. Hover-1 Liberty Wheel Motor Replacement: Schritt 11, Bild 1 von 2 Hover-1 Liberty Wheel Motor Replacement: Schritt 11, Bild 2 von 2
    • Lift motor assembly away from hoverboard.
    • There is a flat section on the motor shaft that needs to point up, towards metal plate.
    • The motor assembly should be flush with side of hoverboard.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S13-G2, White Fall 2018 Mitglied von Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
My bracket the wheel attaches to hoverboard is broke can that portion of board be replaced? Where can I buy it if so?
Adam Vernengo - Antwort
Can I buy a replacement battery side motor for hover1 drive hoverboard. If so, where? Can’t seem to find it on internet
luke-1115@hotmail.com - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 43
Insgesamt: 4,749
