Zum Hauptinhalt wechseln
Hover-1 Matrix Pad Replacement
Was du brauchst
  1. Hover-1 Matrix Pad Replacement, Pad: Schritt 1, Bild 1 von 2 Hover-1 Matrix Pad Replacement, Pad: Schritt 1, Bild 2 von 2
    • Remove the screws on the back of the hoverboard using a Phillips #1 screwdriver.
    • Remove the back shell from the hoverboard.
  2. Hover-1 Matrix Pad Replacement: Schritt 2, Bild 1 von 1
    • Remove the screws from the metal layer inside the hoverboard using a Phillips #1 screwdriver.
  3. Hover-1 Matrix Pad Replacement: Schritt 3, Bild 1 von 1
    • Separate the upper shell of the hoverboard and the metal layer inside.
  4. Hover-1 Matrix Pad Replacement: Schritt 4, Bild 1 von 2 Hover-1 Matrix Pad Replacement: Schritt 4, Bild 2 von 2
    • Start by identifying the motherboard, which is the green pad shown in the picture.
    • Remove the screws on the corners of the motherboard with the Phillips #1 screwdriver and take it off.
    • There are cables attached to the motherboard so go ahead and unattach them.
  5. Hover-1 Matrix Pad Replacement: Schritt 5, Bild 1 von 3 Hover-1 Matrix Pad Replacement: Schritt 5, Bild 2 von 3 Hover-1 Matrix Pad Replacement: Schritt 5, Bild 3 von 3
    • Use picture 1 as a guide and move the motherboard to the other side.
    • Identify the two black rubber buttons that are shown in the second picture.
    • Remove the two rubber buttons using the Phillips #1 screwdriver.
  6. Hover-1 Matrix Pad Replacement: Schritt 6, Bild 1 von 1
    • Removing the rubber buttons in the previous step allows you to take the pad off.
    • Finally, take off the old pad and put on a new pad.
Abschluss
To reassemble your device, follow these instructions starting with step number 6 and finishing with step number 1.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jici Zhuang
362 Reputation
2 Anleitungen geschrieben
UC Davis, Team S7-G2, Lore Fall 2018 Mitglied von UC Davis, Team S7-G2, Lore Fall 2018
UCD-LORE-F18S7G2
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 352
