Zum Hauptinhalt wechseln
Hover-1 Matrix Right Gyroscope Sensor Board Replacement
Was du brauchst
  1. Hover-1 Matrix Right Gyroscope Sensor Board Replacement, Right Gyroscope Sensor Board: Schritt 1, Bild 1 von 3 Hover-1 Matrix Right Gyroscope Sensor Board Replacement, Right Gyroscope Sensor Board: Schritt 1, Bild 2 von 3 Hover-1 Matrix Right Gyroscope Sensor Board Replacement, Right Gyroscope Sensor Board: Schritt 1, Bild 3 von 3
    • Locate and use the screw driver and 54 bit as shown in figure 3. Use screw driver to remove screws on the back of the hover board as shown in figure 1. Remove the back shell as shown in figure 2.
  2. Hover-1 Matrix Right Gyroscope Sensor Board Replacement: Schritt 2, Bild 1 von 2 Hover-1 Matrix Right Gyroscope Sensor Board Replacement: Schritt 2, Bild 2 von 2
    • Locate green electric boards at both ends of the hover board. These green boards are the gyroscopes. Use the screw driver to remove the screws from the corners of the green boards as shown in figure 1.
Abschluss
Qingxi Liu
85 Reputation
1 Anleitung geschrieben
UC Davis, Team S7-G2, Lore Fall 2018 Mitglied von UC Davis, Team S7-G2, Lore Fall 2018
UCD-LORE-F18S7G2
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 433
