Einleitung
This guide for the Hover-1 Maverick guides users in replacing the battery in their device. The battery is crucial in powering the hoverboard. Symptoms of having a faulty battery include the device not being able to move, hold a charge, or power on.
Was du brauchst
Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
Remove the shell.
Remove the four 8mm Phillips #1 screws holding down the black plastic casing.
Lift off the black plastic retaining bracket.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
What voltage should the battery put out? Mines is 30v, charger is green at the wall but still the board won’t turn on
