Zum Hauptinhalt wechseln
Hover-1 Maverick Motor Wheel Replacement
Was du brauchst
  1. Hover-1 Maverick Motor Wheel Replacement, Motherboard: Schritt 1, Bild 1 von 3 Hover-1 Maverick Motor Wheel Replacement, Motherboard: Schritt 1, Bild 2 von 3 Hover-1 Maverick Motor Wheel Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Open the shell.
    • There is one motherboard on each side of the device located near the wheels.
  2. Hover-1 Maverick Motor Wheel Replacement: Schritt 2, Bild 1 von 2 Hover-1 Maverick Motor Wheel Replacement: Schritt 2, Bild 2 von 2
    • Disconnect the battery to prevent any electrical currents from coming through the wires.
  3. Hover-1 Maverick Motor Wheel Replacement: Schritt 3, Bild 1 von 2 Hover-1 Maverick Motor Wheel Replacement: Schritt 3, Bild 2 von 2
    • Squeeze and pull on the wires to detach them from the motherboard.
  4. Hover-1 Maverick Motor Wheel Replacement: Schritt 4, Bild 1 von 2 Hover-1 Maverick Motor Wheel Replacement: Schritt 4, Bild 2 von 2
    • Remove the four 8mm Phillips #1 screws.
    • Remove the motherboard from the device.
    • Repeat for the other motherboard.
  5. Hover-1 Maverick Motor Wheel Replacement, Motor: Schritt 5, Bild 1 von 2 Hover-1 Maverick Motor Wheel Replacement, Motor: Schritt 5, Bild 2 von 2
    • After the motherboard is removed from either side, remove the four 15 mm hex screws with a 5mm Allen wrench.
    • Remove the metal covering from over the motor.
  6. Hover-1 Maverick Motor Wheel Replacement: Schritt 6, Bild 1 von 1
    • The motor is attached to the wheel, so in order to remove the motor, you must take out the entire wheel.
Abschluss
Piper Feldman
409 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S2-G2, White Winter 2020 Mitglied von Cal Poly, Team S2-G2, White Winter 2020
CPSU-WHITE-W20S2G2
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 457
