Einleitung
If the LED headlights on your Nomad do not light up when the hoverboard is powered on, your headlights may be damaged. Follow this guide to replace the headlights in the Hover-1 Nomad.
Was du brauchst
Break the two warranty stickers by poking a screwdriver through them or peeling them off.
Remove the following twenty screws by rotating the screwdriver counterclockwise:
Eight 16.2mm Phillips #2 screws
Eight 15mm Phillips #2 screws
Four 19.1mm Phillips #2 screws
Use a nylon spudger to pry the metal handle away from the outer shell.
Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
Lift the hoverboard off the metal handle.
Repeat for the handle on the other side of the hoverboard.
Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
Charging port wires
Speaker assembly wires
Power button wires
Headlight wires
Remove the two 13mm Phillips #1 screws by rotating the screwdriver counterclockwise.
Eine weitere Person hat diese Anleitung absolviert.
