Zum Hauptinhalt wechseln
Hover-1 Nomad Outer Shell Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Hover-1 Nomad Outer Shell Replacement, Outer Shell: Schritt 1, Bild 1 von 3 Hover-1 Nomad Outer Shell Replacement, Outer Shell: Schritt 1, Bild 2 von 3 Hover-1 Nomad Outer Shell Replacement, Outer Shell: Schritt 1, Bild 3 von 3
    • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
    • Remove the following twenty screws by rotating the screwdriver counterclockwise:
    • Eight 16.2mm Phillips #2 screws
    • Eight 15mm Phillips #2 screws
    • Four 19.1mm Phillips #2 screws
    • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
    • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
  2. Hover-1 Nomad Outer Shell Replacement: Schritt 2, Bild 1 von 3 Hover-1 Nomad Outer Shell Replacement: Schritt 2, Bild 2 von 3 Hover-1 Nomad Outer Shell Replacement: Schritt 2, Bild 3 von 3
    • Use a nylon spudger to pry the metal handle away from the outer shell.
    • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
    • Lift the hoverboard off the metal handle.
    • Repeat for the handle on the other side of the hoverboard.
  3. Hover-1 Nomad Outer Shell Replacement: Schritt 3, Bild 1 von 1
    • Lift the plastic cover on each side up and away from the device.
    • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
  4. Hover-1 Nomad Outer Shell Replacement: Schritt 4, Bild 1 von 2 Hover-1 Nomad Outer Shell Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
    • Charging port wires
    • Speaker assembly wires
    • Power button wires
    • Headlight wires
    • Only the headlight wires need to be disconnected from the other circuit board.
    • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Samuel Frazee
1.015 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S15-G1, White Fall 2018 Mitglied von Cal Poly, Team S15-G1, White Fall 2018
CPSU-WHITE-F18S15G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 65
