Einleitung
If your Nomad doesn't play audio even while booting up, your speaker assembly may be damaged. Follow this guide to replace the speaker assembly in your Hover-1 Nomad.
Was du brauchst
Break the two warranty stickers by poking a screwdriver through them or peeling them off.
Remove the following twenty screws by rotating the screwdriver counterclockwise:
Eight 16.2mm Phillips #2 screws
Eight 15mm Phillips #2 screws
Four 19.1mm Phillips #2 screws
Use a nylon spudger to pry the metal handle away from the outer shell.
Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
Lift the hoverboard off the metal handle.
Repeat for the handle on the other side of the hoverboard.
Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
Charging port wires
Speaker assembly wires
Power button wires
Headlight wires
Remove the two 13mm Phillips #1 screws in the corners of the speaker assembly circuit board.
Remove the two 13mm Phillips #1 screws fastening the speaker retention bracket to the shell.
Break the glue connecting the speaker to the outer shell by prying the speaker up with a nylon spudger.
Lift the speaker off the outer shell.
Use a nylon spudger to scrape the fabric speaker cover off the outer shell.
Peel the fabric off the outer shell.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
