Einleitung
The battery for the Hover-1 Superstar can cause many different problems when it is faulty or not working. This guide will show you the steps that go along with replacing the battery.
Was du brauchst
Flip your Hover-1 Superstar device upside down.
Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
Remove the bottom case. Be careful of the connector holding the case and the device together.
Locate the cable connected to the front lights.
Pull apart the wires until the black clip separates.
Locate the four 14mm screws securing the battery bracket.
Remove the screws with a Phillips #1 screwdriver.
Pull on the battery until it separates from the hover board. You may need to use some force.
Pull the battery out of the hoverboard. Move wires away from the battery if necessary.
