Zum Hauptinhalt wechseln
Hover-1 Superstar Front Bumper LED Replacement
Was du brauchst
  1. Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: Schritt 1, Bild 1 von 3 Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: Schritt 1, Bild 2 von 3 Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: Schritt 1, Bild 3 von 3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
  2. Hover-1 Superstar Front Bumper LED Replacement: Schritt 2, Bild 1 von 1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
  3. Hover-1 Superstar Front Bumper LED Replacement, Front Bumper LED: Schritt 3, Bild 1 von 1
    • Grab the wire of the connector you disconnected from the case earlier and slide the entire light out away from the case.
Abschluss
Keegan
632 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 291
