Zum Hauptinhalt wechseln
Hover-1 Superstar Speaker Replacement
Was du brauchst
  1. Hover-1 Superstar Speaker Replacement, Bottom Case: Schritt 1, Bild 1 von 3 Hover-1 Superstar Speaker Replacement, Bottom Case: Schritt 1, Bild 2 von 3 Hover-1 Superstar Speaker Replacement, Bottom Case: Schritt 1, Bild 3 von 3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
  2. Hover-1 Superstar Speaker Replacement: Schritt 2, Bild 1 von 1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
  3. Hover-1 Superstar Speaker Replacement, Speaker: Schritt 3, Bild 1 von 1
    • Unplug the white connector that connects the speaker itself with the circuit board attached to the bottom of the device case.
  4. Hover-1 Superstar Speaker Replacement: Schritt 4, Bild 1 von 1
    • Unscrew all three 9mm screws with a Phillips #0 screwdriver securing the speaker to the device case.
  5. Hover-1 Superstar Speaker Replacement: Schritt 5, Bild 1 von 1
    • Remove the speaker from its port.
Abschluss
Keegan
632 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 282
