Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip the hoverboard so the bottom is facing up. The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. EINFACH ALLE TABS ÖFFNEN
    RAM Upgrade Kits für Mac
    Kits kaufen
    Genügend RAM
    für alle Tabs
    Kits kaufen
  3. Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard. Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  4. Grip the bottom right panel and lift to remove it. Grip the bottom right panel and lift to remove it. Grip the bottom right panel and lift to remove it.
    • Grip the bottom right panel and lift to remove it.
Abschluss
Dana Ebe
205 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S15-G4, White Fall 2018 Mitglied von Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 36
