Einleitung
If your hoverboard will not turn on, follow this guide to replace the power button.
Was du brauchst
Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
Disconnect the battery by holding the yellow connectors and pulling apart.
Unplug the red and black power button connector on the motherboard by squeezing the connector and pulling away from the board.
Use an adjustable wrench to remove the 14 mm nut holding the button in the shell.
