Einleitung
If your hoverboard will not turn on, retain a charge, move, or spin properly, use this guide to help replace your Hover-1 Titan gyroscope/motherboard.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
Unplug the bottom left connector by squeezing it and pulling it away from the board.
Unplug the white wires by squeezing the connector and pulling away from the board.
Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
Ein weiterer Nutzer hat diese Anleitung absolviert.
