Zum Hauptinhalt wechseln
Hover-1 Ultra Charging Port Replacement
Was du brauchst
  1. Hover-1 Ultra Charging Port Replacement, Charging Port: Schritt 1, Bild 1 von 3 Hover-1 Ultra Charging Port Replacement, Charging Port: Schritt 1, Bild 2 von 3 Hover-1 Ultra Charging Port Replacement, Charging Port: Schritt 1, Bild 3 von 3
    • Orient the hoverboard so that the pads are facing down.
    • With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
    • Carefully remove the shell, lifting directly up.
  2. Hover-1 Ultra Charging Port Replacement: Schritt 2, Bild 1 von 2 Hover-1 Ultra Charging Port Replacement: Schritt 2, Bild 2 von 2
    • Using your hands or a crescent wrench, begin removing the charging port.
    • Turn the charging port counter-clockwise to release it from the shell.
  3. Hover-1 Ultra Charging Port Replacement: Schritt 3, Bild 1 von 3 Hover-1 Ultra Charging Port Replacement: Schritt 3, Bild 2 von 3 Hover-1 Ultra Charging Port Replacement: Schritt 3, Bild 3 von 3
    • Unclip the insulated red and black wires attached to the port from the motherboard
  4. Hover-1 Ultra Charging Port Replacement: Schritt 4, Bild 1 von 3 Hover-1 Ultra Charging Port Replacement: Schritt 4, Bild 2 von 3 Hover-1 Ultra Charging Port Replacement: Schritt 4, Bild 3 von 3
    • Remove the charging port through the assembly.
    • Place new charging port through the assembly.
    • Clip red and black insulated wires into the motherboard.
Abschluss
To reassemble your device, follow the instructions for step 1 in reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Camron Clifton
409 Reputation
3 Anleitungen geschrieben
UC Davis, Team S7-G5, Lore Fall 2018 Mitglied von UC Davis, Team S7-G5, Lore Fall 2018
UCD-LORE-F18S7G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 17
Insgesamt: 744
