Einleitung
Will your Hover-1 Ultra not power up, preventing you from riding it? If you face this problem, it can be fixed with a simple replacement of the power button on your device. You will need a Phillips #1 screwdriver to remove the screws and an adjustable crescent wrench to help remove the button
Was du brauchst
Orient the hoverboard so that the pads are facing down.
With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the hoverboard.
Carefully remove the shell, lifting directly up.
Unscrew the power button using your hands or an adjustable crescent wrench.
Turn the power button counter-clockwise to release from the shell.
Unclip the red and black power cables that are attached to the port from the motherboard.
To reassemble your device, follow the instructions for step 1 in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
