Einleitung
Use this guide to replace the Bluetooth remote control of a Hoverboard.
Be careful! A soldering iron is used in this guide, so take the necessary precautions before starting
Was du brauchst
Remove the 10 screws with a Phillips screwdriver to access the inside of the hoverboard.
The electronic circuit boards are mirrored on both sides, so examine them both to determine which has the Bluetooth setup.
Use a soldering iron to affix the 4 pins of the Bluetooth board onto the hoverboard board
To reassemble your device, Follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
100%
Hier starten ›
4 Kommentare
Hello! Would it be possible to know where to get that bluetooth module? I would like to try that one my hoverboard but cant find the needed part.
Ciao,puoi cercare su EBay AliExpress Wish ed altri store cinesi
Smilzo -
Well after 5 days of search on ali.. ebay.. bangood.. amazon. I still haven't found the good part.
I've ask a lots of sellers and they all replied the module they sell is only for music no app control :(
Nix Mathy devi cercare bene come parola chiave.io li vedo su tanti store
telecomando self balance hoverboard
Smilzo -
