Zum Hauptinhalt wechseln
How To Clean Nikon Coolpix S30 Lens
Was du brauchst
  1. How To Clean Nikon Coolpix S30 Lens, Batteries: Schritt 1, Bild 1 von 2 How To Clean Nikon Coolpix S30 Lens, Batteries: Schritt 1, Bild 2 von 2
    • Slide the battery cover to the right.
    • The hinge is on the left side of the cover which will allow the cover to stay attached.
    Frag FixBot
    Kommentar hinzufügen
  2. How To Clean Nikon Coolpix S30 Lens: Schritt 2, Bild 1 von 2 How To Clean Nikon Coolpix S30 Lens: Schritt 2, Bild 2 von 2
    • Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
    Frag FixBot
  3. How To Clean Nikon Coolpix S30 Lens: Schritt 3, Bild 1 von 1
    • Remove the batteries by gently tipping the camera.
    Frag FixBot
  4. How To Clean Nikon Coolpix S30 Lens, How To Clean Nikon Coolpix S30 Lens: Schritt 4, Bild 1 von 1
    • Remove the four screws the hold the back of the case to the rest of the camera.
    Frag FixBot
  5. How To Clean Nikon Coolpix S30 Lens: Schritt 5, Bild 1 von 1
    • Remove the left screw from the bottom of the camera first. This can be done using the same T5 tip.
    • Unscrew the screw on the right using a different attachment: PH000 (it is a small Phillip's head)
    Frag FixBot
  6. How To Clean Nikon Coolpix S30 Lens: Schritt 6, Bild 1 von 1
    • Remove back case from the rest of the camera carefully.
    Frag FixBot
  7. How To Clean Nikon Coolpix S30 Lens: Schritt 7, Bild 1 von 1
    • Remove the three screws the secure the motherboard to the front case.
    Frag FixBot
  8. How To Clean Nikon Coolpix S30 Lens: Schritt 8, Bild 1 von 2 How To Clean Nikon Coolpix S30 Lens: Schritt 8, Bild 2 von 2
    • Remove the motherboard from the front case.
    • Leave the red and black wire attached but lay the piece in front of the case.
    Frag FixBot
  9. How To Clean Nikon Coolpix S30 Lens: Schritt 9, Bild 1 von 2 How To Clean Nikon Coolpix S30 Lens: Schritt 9, Bild 2 von 2
    • Wipe the lens and the clear plastic on the front case to remove debris.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Penn State, Team 2-4, Kaschak Winter 2015 Mitglied von Penn State, Team 2-4, Kaschak Winter 2015
PSU-KASCHAK-W15S2G4
4 Mitglieder
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
The first three steps are redundant because you already included the prerequisite guide for removal of the batteries.
Dylan Keiter - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 2,087
