Zum Hauptinhalt wechseln
How To Fix A Frayed Buttonhole
Was du brauchst
  1. How To Fix A Frayed Buttonhole, How To Fix A Frayed Buttonhole: Schritt 1, Bild 1 von 3 How To Fix A Frayed Buttonhole, How To Fix A Frayed Buttonhole: Schritt 1, Bild 2 von 3 How To Fix A Frayed Buttonhole, How To Fix A Frayed Buttonhole: Schritt 1, Bild 3 von 3
    • With a seam ripper, carefully remove all the threads from the frayed buttonhole.
  2. How To Fix A Frayed Buttonhole: Schritt 2, Bild 1 von 1
    • Find a thread that closely matches the thread on the pants.
  3. How To Fix A Frayed Buttonhole: Schritt 3, Bild 1 von 3 How To Fix A Frayed Buttonhole: Schritt 3, Bild 2 von 3 How To Fix A Frayed Buttonhole: Schritt 3, Bild 3 von 3
    • Holding the fabric right-side up with the buttonhole horizontal, begin stitching at the edge.
    • Start from the inner side.
    • Be cautious of your hand placement when pushing the needle through the fabric.
  4. How To Fix A Frayed Buttonhole: Schritt 4, Bild 1 von 3 How To Fix A Frayed Buttonhole: Schritt 4, Bild 2 von 3 How To Fix A Frayed Buttonhole: Schritt 4, Bild 3 von 3
    • The needle should be on the front side.
    • Put the needle in between the layers of fabric and pull it through towards the inner side, securing the fabrics together.
  5. How To Fix A Frayed Buttonhole: Schritt 5, Bild 1 von 3 How To Fix A Frayed Buttonhole: Schritt 5, Bild 2 von 3 How To Fix A Frayed Buttonhole: Schritt 5, Bild 3 von 3
    • The needle is on the inner side.
    • Pull the needle through the buttonhole towards the other side.
    • Do not put the needle through the fabric.
  6. How To Fix A Frayed Buttonhole: Schritt 6, Bild 1 von 2 How To Fix A Frayed Buttonhole: Schritt 6, Bild 2 von 2
    • Continue making buttonhole stitches along the side of the buttonhole.
    • Keep the stitches close together.
  7. How To Fix A Frayed Buttonhole: Schritt 7, Bild 1 von 3 How To Fix A Frayed Buttonhole: Schritt 7, Bild 2 von 3 How To Fix A Frayed Buttonhole: Schritt 7, Bild 3 von 3
    • On the back side, tie a knot to seal the thread.
  8. How To Fix A Frayed Buttonhole: Schritt 8, Bild 1 von 2 How To Fix A Frayed Buttonhole: Schritt 8, Bild 2 von 2
    • After sealing the knot, the button should fit into the buttonhole.
Abschluss
This guide should be easy to anybody with sewing experience, and if you don’t have sewing experience, then this guide should be a good beginners guide on how to get familiar with sewing.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Adina Asif
184 Reputation
1 Anleitung geschrieben
York University, Team S2-G27, O'Regan Winter 2021 Mitglied von York University, Team S2-G27, O'Regan Winter 2021
YORK-O'REGAN-W21S2G27
2 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 42
Letzte 30 Tage: 224
Insgesamt: 7,240
