Einleitung
Do you have any ripped khaki pants that you do not wear anymore? Well here is a guide that will give you a solution of a way to repair your pants and put them back on your waist.
Was du brauchst
Examine the damaged area.
Make sure to clean all the debris from the tear.
Pull needle and thread through pants until there is only 2 inches of thread left.
Tie a knot at the end of the remaining 2 inches.
Take the needle and pin it through right next to the previous spot.
Pull all the way through until thread is tight.
Repeat this process until you reach the end of the hole.
Wrap the thread three times around the needle.
Pull the needle until the thread is tight.
Now put your khaki pants on because they are now wearable again and practically new!
Now your old ripped pants look practically new and you can begin wearing them again.
6 weitere Personen haben diese Anleitung absolviert.
5 Kommentare
it's 100% not ok...... i con do it so 99% ok
and 100% maching
Iam shafik i can't do it's and 100% maching
What about if you’re in school and your pants rip?
is it smooth when you fix it? i use these for school and dont want it to show
