Einleitung
Do you have an LP record that is skipping? Use this guide to get your record back to sounding like new.
Was du brauchst
Identify the problem area by playing the LP record on a turntable.
Note the damaged area.
Brush off the record with a lint-free cloth or record-cleaning brush in a circular brushing motion.
Put about ¼ tsp. (1.25ml) of soap in the sink.
Fill the sink with about 3-4 inches of lukewarm water.
Put the record in the sink, submerging the record.
Turn the record over to ensure both sides of the record were submerged in the water.
Allow the soapy water to drain from the sink.
Put the LP record in the sink and run cold water over the LP record.
Take a dry lint-free cloth and dry the LP record in a circular motion until wet spots are visibly gone.
After the LP Record is completely dry, you will be able to play and enjoy the repaired record.
If the LP record is not fixed, this could indict a deep scratch that will need to be repaired by a professional.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
This is the worst advice I’ve ever read.
Did the method work though?!
