Einleitung
Did you leave the cap off your marker again? Did the ink dry out? Keep your markers out of the trash by following these quick and easy steps.
Was du brauchst
Obtain the items necessary.
2 Tablespoons Of Vinegar
3 Cups Of Warm Water
The Dried Out Water Based Marker
A Small Bowl
A Paper Towel
Fill the bowl with 3 cups of warm water.
Add 2 tablespoons of vinegar into the bowl with water.
Mix in the vinegar.
Place the marker tip down into the bowl.
Make sure the cap is off the marker. Set the cap aside for later use.
Allow the marker to sit for approximately 5 minutes in the water.
Remove the marker from the bowl and place onto the paper towel.
Do not remove the marker until some ink is released into water.
Wrap the marker in the paper towel and allow it to sit.
Wait approximately two minutes.
Be sure to place the cap back on the marker.
Make sure you lay the marker on its side.
Allow the marker to sit for up to 15 minutes before you start writing with it.
Pick up the marker and start writing.
Watch as the once dried out marker starts to work again.
If the marker does not work after steps 1-5, try placing the tip end in the vinegar alone and let sit in the vinegar for 2 minutes.
Allow the marker to dry for at least 15 minutes before you start using it.
Repeat as necessary for all water based markers.
20 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
I had been throwing my dried up highlighters for years...thanks so much for sharing this info
Works very, very well! Thank you, Kyle…
Agreed! Thank you so much still in 2021!
