Einleitung
If your Adidas Gazelles have seen better days and have acquired a hole in their sole, then this is the guide for you. This guide will walk you through how to repair a hole in the sole of your Adidas Gazelles in 7 easy steps. Repairing the hole in your Gazelles will protect them from water damage and restore them to their former glory.
Was du brauchst
To begin, clean the Adidas Gazelles with some water on a towel.
Carefully use the utility knife to free the hole of any excess material.
Make sure and clear the Gazelles of any debris that that could be stuck under the loose squares of the sole.
Apply shoe goo to the inside of the hole in the sole of your Adidas Gazelles.
If there is anywhere else on your Gazelle's sole that could use additional protection, apply shoe goo to those surfaces as well.
Take your putty knife and smooth the shoe goo flush to the surface of the sole.
Try to spread the shoe goo in one direction to increase surface smoothness.
After 24 hours, use 150 grit sandpaper to rub down the surface of your filled hole to create a smooth surface.
Now with the hole repaired your Gazelles are ready for action. With the proper care you can extend their life for many years to come.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
