Einleitung
Many people, in all fields of career and studies, use books. Whether you are a college student renting a textbook or a person who loves to read in their downtime, books can get expensive and damaged easily. They are prone to tearing, whether it be from old-age fragility to improper care.
This repair guide is the perfect tool for those who wish to repair torn pages using household items and minimal time. Your pages will look good as new, and it can all be accomplished in a few easy steps.
It is recommended to not use an excessive amount of fabric glue during the repair, as this may make it difficult when removing the wax paper later in the process. In Step 4, the use of a paintbrush and fabric glue requires the skills of precision and accuracy, so be sure to remove excess glue and instead apply only in necessary areas.
Was du brauchst
Lay out all of the equipment needed for the repair.
Grab the fabric glue and squeeze a line of glue all the way along the crevice (tear).
Use a small paintbrush to apply a moderate amount of glue along the edges of the ripped areas.
Wrap the closed book with several rubber bands to squeeze and compress during drying time.
Let the glue dry for 6 hours minimum to ensure that it dries completely.
Carefully peel the top sheet of wax paper first, and then remove the bottom one afterwards.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
