Zum Hauptinhalt wechseln
How To Hem Jean Shorts
Was du brauchst
    1. How To Hem Jean Shorts, How To Hem Jean Shorts: Schritt 1, Bild 1 von 1
      • Use a ruler to measure and mark your preferred length of the shorts with fabric chalk.
      • Measure each side carefully and make sure both legs are marked evenly.
      Frag FixBot
      Kommentar hinzufügen
    2. How To Hem Jean Shorts: Schritt 2, Bild 1 von 1
      • Mark an additional line 1 inch below your chosen length to allow room for folding the hem.
      • Use sharp fabric scissors to cut across each leg along the lower chalk line.
      Frag FixBot
    3. How To Hem Jean Shorts: Schritt 3, Bild 1 von 3 How To Hem Jean Shorts: Schritt 3, Bild 2 von 3 How To Hem Jean Shorts: Schritt 3, Bild 3 von 3
      • Fold the bottom edge of each leg up 1/2 inch, then fold it again to tuck the raw edge inside.
      • Pin the fold in place all the way around the leg to keep it secure.
      • Double check that both hems are even before moving to the next step.
      Frag FixBot
    4. How To Hem Jean Shorts: Schritt 4, Bild 1 von 1
      • Place the folded edge of one leg under the presser foot of the sewing machine.
      • Lower the presser foot to the fabric before you begin sewing.
      Frag FixBot
    5. How To Hem Jean Shorts: Schritt 5, Bild 1 von 1
      • Carefully sew along the folded edge, keeping the stitch even and close to the inside edge of the fold.
      • Backstitch at the beginning and end to secure the seam.
      • Repeat the same process on the other leg.
      Frag FixBot
    6. How To Hem Jean Shorts: Schritt 6, Bild 1 von 2 How To Hem Jean Shorts: Schritt 6, Bild 2 von 2
      • Once the hems are sewn, trim off any loose threads.
      • Use an iron to press the hem flat for a clean finish.
      Frag FixBot
Ziellinie
Tiffany Ngo
133 Reputation
1 Anleitung geschrieben
Austin Community College, Team 1-5, Kapoor Summer 2025 Mitglied von Austin Community College, Team 1-5, Kapoor Summer 2025
AUSTINCC-KAPOOR-SU25S1G5
1 Mitglied
11 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 92
Insgesamt: 610
